I have a problem with the “color” image mapping. When I put an image in it then It s get like an environment mapping. It means that it s not fixed to the object… Same problem when I use picture frame. The image is moving like an environment mapping…why?
That sounds like something I’ve seen when the graphics card driver needs to be updated or the GPU isn’t being used by Rhino for some reason. Assuming you are in Rhino 5 for Windows, check Options>View>OpenGL to see if accelerated hardware is enabled and if the driver is old.
