Hi guys,
I have a set of walls and they have a property called type. I want to colorize them so same type of walls will have the same color. I found a way using Gradient but I don’t really want to use it because I have to set Gradient color manually. I want it to set a random color and if possible I want to change those colors as well. What should I do to achieve that? I couldn’t really understand how Color Wheel works.
Any help is welcomed. Rhino file and image that explains the final result that i want to have is below👇.
Color Walls by Type.3dm (2.5 MB)
