No. I want to collect - into a list/sequence - points that are 1 mm apart (Edit: all points are originally 1 mm apart, but in the gaps the points are removed). So, when distance is bigger than 1 mm, a new list/sequence should start. So on the same curve there can be multiple point lists/sequences (with 1 mm distance between the points).
The 1mm distance is only a criteria for which points should go together to form polyline, or interpolate curve.
Greater distance than 1 mm means that there’s a gap between the point-sequences (= interpolate curves).
The second picture above shows the desired end result - curve segments which are feed into Pipes. (maybe the resolution was too low, but the first picture shows points on the curve, while the second picture shows the resulting Pipes which I want).
