I am trying to install Cockroach 1.00 , pointcloud processing for Grasshopper by placing the extracted files in the GH library folder in AppData. But I get the error message in the command prompt when I start Rhino. It says that CockroachGH is not readable and supported. It seems to be a problem with compability in .NET Framework ?
Anyone have a clue
Hi Fredrik!
The recommended way is to install plug-ins through the PluginManager
Please run the Rhino SystemInfo
command and copy-paste the result here.
Hilsen,
Hi Wim!
I deleted the extracted files in the library and uninstalled Cockcroach ver 0.01 an installed via pluginmanager (wich was possible after unblocking the file in properties) but I still have the same problem
Hers syinfo;
Rhino 7 SR9 2021-8-10 (Rhino 7, 7.9.21222.15001, Git hash:master @ 190335c3fb65efe86c302714a8959a7dadfe667b)
License type: Commercial, build 2021-08-10
License details: Cloud Zoo
Windows 10.0.19043 SR0.0 or greater (Physical RAM: 32Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 9-30-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 456.71
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 9-30-2020
Driver Version: 27.21.14.5671
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
D:\Dropbox\ProgramBackup\Rhinoceros\Mina verktyg\BoltGen\BoltGen1_63.rhp “BoltGen” 0.0.0.0
C:\Program Files\ADA 3D\Mesh2Surface for Rhino 6\m2s_for_Rhino.rhp “MESH2SURFACE”
C:\ProgramData\McNeel\Rhinoceros\7.0\Plug-ins\Twinmotion Direct Link 2020.2 (e24ee14a-9514-47da-8fe6-f6e61b20160e)\Twinmotion Direct Link 2020.rhp “Twinmotion Direct Link 2020” 1.0.6.0
D:\Dropbox\Setup\Rhinoceros\Grasshopper\cockroach\CockroachRhino.rhp “CockroachRhino” 1.0.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 7\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 7\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 7\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Alerter.rhp “Alerter”
C:\Program Files\Rhino 7\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Grasshopper\GrasshopperPlugin.rhp “Grasshopper” 7.9.21222.15001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.9.21222.15001
I solved it!! You have to unblock the .gha file too!! Now its running!
/F
Glad you worked it out.
I see I messed up and wrote PluginManager
where I was trying to write PackageManager
The PackageManager
is the preferred way to install plug-ins (not all plug-ins are available as packages but Cockroach is). Sorry about that…
Ok Thanks! Note: The version of Cockroach in PakageManager (0.01) is the Rhino version (runs
with commando prompt commands) and doesnt install to Grasshopper. The 1.00 version you have to download at Food4Rhino and install via PluginManager, so you were actually right…
