lucasc
(Lucas)
#1
I am trying to design this structure:
It’s a Brazilian word, and I couldn’t find the translation to it. Sorry
Anyway, best results I got was with Loft and Blend Surface, but I cannot get a smooth surface, always end up getting some crease.
I will 3D Print it later ^^
STL Loft:
STL BlendSrf:
Latticework.3dm (2.9 MB)
I used an Ellipse to cut the surface. Using Loft I also added another Ellipse at the middle.
How would you do it?
12Lab
(nachetz)
#2
i’d use subD, did you try it?
lucasc
(Lucas)
#3
Hmm, I started it in SolidWorks and was trying to design it with it NURBS.
Will try with SubD, thanks. ^^
12Lab
(nachetz)
#4
If you prefer nurbs:
it’s just a fast sketch
Latticework_02.3dm (853.3 KB)
lucasc
(Lucas)
#5
Hmmm
You extruded the Ellipse, then used BlendSrf?
The Zebra looks disconnected, but the STL is fine ^^
12Lab
(nachetz)
#6
I’d make a strip in the middle, blendsrf and adjust surface blend
