Coarse wire display when not selected
Wire display is coarse when the object is not selected.
2025-09-04_Tess.3dm (205.8 KB)
There are 2 surfaces, one is selected.
The selected one looks fine; the unselected one does not.
When none is selected, they both are not nice.
This is in current V8:
V9 OpenGL looks similar:
V9 Direct3D is even coarser, too coarse IMO:
V5 :squinting_face_with_tongue:
Yes, I restarted V9 after setting the display pipeline.
Please run SystemInfo command in Rhino and send us the results.
Ok :saluting_face:
Rhino 8 SR23 2025-8-20 (Rhino 8, 8.23.25232.17001, Git hash:master @ 11021a7ca6f46cb8100ec021880f8c144c5f5ab5)
License type: Commercial, build 2025-08-20
License details: Cloud Zoo
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 32GB)
.NET Framework 4.8.9310.0
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 572.16
- Windows Main Display attached to adapter port 0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-26-2025
Driver Version: 32.0.15.7216
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
C:\Program Files\Common Files\McNeel\Rhinoceros\8.0\Plug-ins\XNurbs (80be33b0-13b2-4ac4-9c77-03829214f9e9)\7.0.1.1\XNurbsRhino8.rhp “XNurbs”
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.23.25232.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.23.25232.17001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.23.25232.17001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.23.25232.17001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.23.25232.17001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.23.25232.17001
Rhino 9 SR0 2025-8-26 (Rhino WIP, 9.0.25238.12305, Git hash:master @ ba2cf38650b3af8790c8629a1f03c10309209bd2)
License type: Commercial, build 2025-08-26
Expires on: 2025-10-10
Standard graphics configuration using OpenGL
Primary display: NVIDIA GeForce RTX 2070 (NVidia) Memory: 8GB, Driver date: 1-26-2025 (M-D-Y). OpenGL(4.6.0 NVIDIA 572.16)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 8x
Render version: 4.6
OpenBLAS: OpenBLAS 0.3.29 DYNAMIC_ARCH NO_AFFINITY Zen MAX_THREADS=64.
C:\Program Files\SimLab\Plugins\SimLab 3D PDF From Rhino 6\plugins\SimLabPDFExporter.rhp “SimLab PDF Exporter”
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 9.0.25238.12305
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxrhino.rhp “3Dconnexion 3D Mouse”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
I extracted the boundary of the longer surface and rebuilt the two long bottom edges with 16 points, what rebuild suggested and used sweep2 to make a new tunnel. Looks better. Guess this is not about the surface so I deleted the surface and kept just two curves in the file.
When viewed more from the top, the facetting effect is not visible…
Latest WIP with Direct3D
2025-09-04_Tess_mrtn.3dm (116.3 KB)
Perhaps @stevebaer or @jeff …
Is there a setting that controls the tesselation precision?
And why is it so much better when an object is selected?
The Direct3D display is far too coarse.
Hi -
Looks like this is WIP…
Thanks Wim.
And that’s why I reported it :grinning_face:
This is from todays (2025-10-22) news:
I tried with the file in the first post.
Looks the same as before.
