Hi guys.
I make customized user interface in rhinoceros with C++.
In the project, I make new class which inherited from CRhinoTabbedDockBarDialog
, and the class have some controls of MFC.
original DockBarDialog
class is (some codes which are no related are deleted.)
CUtDockDialog.h
class CUtDockDialog : public CRhinoTabbedDockBarDialog
DECLARE_DYNCREATE(CUtDockDialog)
public:
CUtDockDialog();
virtual ~CUtDockDialog();
enum { IDD = IDD_UTDOCK_DOCKBAR_DIALOG };
CUtPgCtrl UtPg;
static ON_UUID ID();
const wchar_t* Caption() const override;
ON_UUID TabId() const override;
ON_UUID PlugInId() const override;
void OnShowTab(const class CRhinoUiPanel& db, bool bShowTab, const ON_UUID& dockBarId) override;
protected:
virtual void DoDataExchange(CDataExchange* pDX) override;
virtual BOOL OnInitDialog() override;
private:
DECLARE_MESSAGE_MAP()
void InitUiSetting();
CUtDockDialog.cpp
IMPLEMENT_DYNCREATE(CUtDockDialog, CRhinoTabbedDockBarDialog)
////////////////////// PUBLIC //////////
/////////// CONSTRUCTOR & DESTRUCTOR
CUtDockDialog::CUtDockDialog()
: CRhinoTabbedDockBarDialog()
CUtDockDialog::~CUtDockDialog()
/////////// STATIC METHOD
ON_UUID CUtDockDialog::ID()
char *uuid = "????????????????????????????";
return ON_UuidFromString(uuid);
/////////// OVERRIDE METHOD
const wchar_t* CUtDockDialog::Caption() const
return L"UtDock";
ON_UUID CUtDockDialog::TabId() const
return ID();
ON_UUID CUtDockDialog::PlugInId() const
return UtDockPlugIn().PlugInID();
void CUtDockDialog::OnShowTab(const class CRhinoUiPanel& db, bool bShowTab, const ON_UUID& dockBarId)
UNREFERENCED_PARAMETER(db);
UNREFERENCED_PARAMETER(bShowTab);
UNREFERENCED_PARAMETER(dockBarId);
////////////////////// PROTECTED //////////
void CUtDockDialog::DoDataExchange(CDataExchange* pDX)
CRhinoTabbedDockBarDialog::DoDataExchange(pDX);
DDX_Control(pDX, IDC_UTDOCK_PG, this->UtPg);
BOOL CUtDockDialog::OnInitDialog()
/* some operation of initialization */
return TRUE;
////////////////////// PRIVATE //////////
/////////// METHOD
BEGIN_MESSAGE_MAP(CUtDockDialog, CRhinoTabbedDockBarDialog)
ON_WM_CREATE()
ON_WM_DESTROY()
ON_CBN_SELCHANGE(IDC_COMBO1, &CUtDockDialog::OnPsCbnSelchange)
END_MESSAGE_MAP()
int CUtDockDialog::OnCreate(LPCREATESTRUCT lpCreateStruct)
return CRhinoTabbedDockBarDialog::OnCreate(lpCreateStruct);
void CUtDockDialog::OnDestroy()
CRhinoTabbedDockBarDialog::OnDestroy();
And, the class have original control class which inherited from CMFCPropertyGridCtrl
CUtPgCtrl.h
class CUtPgCtrl : public CMFCPropertyGridCtrl
public:
CUtPgCtrl();
void UpdateCUtPgProperties(UINT index);
protected:
BOOL ValidateItemData(CMFCPropertyGridProperty* pProp) override;
CUtPgCtrl.cpp
CUtPgCtrl::CUtPgCtrl():CMFCPropertyGridCtrl()
/////////// METHOD
void CUtPgCtrl::UpdateCUtPgProperties(UINT index)
At the program, CUtPgCtrl
class constructor and methods are called two times.
I thought the problems depend on the DoDataExchange
method, and I made similar application without Rhino enviroment. At the Application, I cannot get same behavior, so I thought the problems is depend on Rhinoceros API.
By the problem, I couldn’t control rhinoceros application state well.
If you know the solution of the problem or know MFC application , please contact me.
Thank you.
