CloudZoo issue
Hi, I’m new in here.
We did just upgrade from Rh5 to Rh6 and configure the CloudZoo.
We run it on 2 Computers and I did configure the Login on both Computers wrong.
I did put login 1 on Computer 2 and Login 2 on Computer 1.
How Can I Change this?
Thank you
Hi @ch.goerner - I’ve moved this to a new topic, as it doesn’t pertain to the LAN Zoo.
– Dale
If I understand the problem correctly, you can start Rhino V6 on both computers, then type the Logout command.
This will close Rhino.
Then start Rhino again and login using the accounts you prefer.
Any luck?
Yes, it did work.
Thank you
Christian Görner
