I am trying to make a solid from this complicated loft… the problem is that the cap function isn’t working and is driving me nuts, anybody able to solve this?
It’s the last step in this process,…
only two things, change the boolean to false
and close
the loft
Loft.gh (17.8 KB)
Thank you! I tried it, but the cap is now just the loft so it is still open at the top and bottom. In your example, it works with some layers but not with all the layers, the thing is that lofting this is a handful because I need the lofting to go straight up instead of wiggling what it does.
even if I bake the geo, brep -> cap I get no results
reducing the number of points of this variable closes correctly
Loft.gh (12.5 KB)
