My rhino object has hexagonal pattern on the surface with each hexagon separated by tiny dent (rift) on their boundary. I like to close this dent. If I delete the hexagonal pattern, my surface will be thin, which I don’t want. How can I close this rift separating hexagon on the surface?
Hello- you can Untrim the hexagons and return to the outer surfaces that you started with. You’ll end up with duplicates, so get rid of those (SelDup then Delete)
