Dear All,
Is there a way to identify the closest points between two lines, which are not intersecting , but crossing each other at certain distance.
I really need the solution.
If there is any Grasshopper component already exist, then please let me know.
If I need to develop a custom plugin then please give me some clue about the algorithm.
Many thanks in advance.
T
Curve Proximity component will solve the closest distance between the two lines
the line line intersection component will give you that point
Many Thanks Jeff ! it works.
