Hello
I’m having a problem with a larger model. I’ve attached a section of the model as a GH file.
I created an intersection point between the surface and the lines using Surface | Curve. At a certain distance, I have a local line defined in Rhino, not created in Grasshopper. From each previously created intersection point, a line should intersect the local line at a 90° angle. However, I keep getting the error “Data Conversion failed from Curve to point”. Does anyone have any ideas on how to solve this problem?
Frank
260131_Community_CP.gh (19.9 KB)
