I am trying to run Closest Point component in parallel since it runs as many times as Points you input. It Keeps giving me an error (“Data conversion failed from Number to Point”) when trying to run it in parallel but it works fine when using it without it.
import ghpythonlib.components as gh
import ghpythonlib.parallel
def cls_point(pt):
new_pt = []
for i in range(len(pt)):
temp = gh.ClosestPoint(pt[i], pts)[0]
new_pt.append(temp)
return(new_pt)
if parallel:
a = ghpythonlib.parallel.run(cls_point, pt, True)
else:
a = cls_point(pt)
The documentation string from ghpythonlib.parallel.run says:
for each item in data_list execute the input function. Execution is
done on as many threads as there are CPUs on the computer.
Parameters:
function: function to execute for each item in the data_list
data_list: list, tuple, or other enumerable data structure
flatten_list [opt]: if True, when results are lists of lists the
results are flattened into a single list of results. If this is True,
you cannot depend on the result list being the same size as the input list
Returns:
list of results containing the return from each call to the input function
So it is enumerating the list you pass in the data_list parameter, running your function on each item and returning the combined results of each call in a list.
If you change your code to this, it will work as you are expecting:
def cls_point(pt):
if parallel:
return gh.ClosestPoint(pt, pts)[0]
new_pt = []
new_pt.append(temp)
return(new_pt)
if parallel:
else:
a = cls_point(pt)
