I have been trying to sweep between two planes along a closed curve, when the curve is open the sweep works. Any help would be greatly appreciated.
Thanks,
Tom
Sweep1_between planes.gh (7.0 KB)
Thanks,
Tom
Thanks once again, works perfectly.
Sorry, this is an extension of the original question. When I apply this to multiple sections the sweep only works reliably to the first section and fails on the ones that fall outside of the domain. Iām going in circles trying to fit the domain so it can be adjusted parametrically, and I have had no luck creating a sweep on the last pair of curves. Any suggestions would be greatly appreciated.
Closed sweep 1_multiple sections.gh (9.3 KB)
Hey !
Do you really need that second circle for each tubes?
If not, you could go for something like this
Closed sweep 1_multiple sections.gh (7.2 KB)
Let me know if this is ok for you !
Antoine,
No I think your right, that looks much more streamlined. I will give it a closer look when I am at my computer.
