Closed solid from open curves
Hello, new to both Rhino and Grasshopper.
I want to make a solid from 3 curves. I first Loft, then create the “end” surface. No way to fill the top and bottom surface which I would need to use “Boundary Volume”
The idea is to then do Solid Intersection to get the common solid between these 2 guys
help_solid_from_loft.gh (37.2 KB)
help_solid_from_loft_re.gh (37.1 KB)
The loft using three curves was messy, can you skip the middle one?
solid_from_loft_2020Dec21a.gh (38.4 KB)
Thank you! I need some time to get what’s happening.
Thanks! As with the answer above, I need to wrap my head around that to get what you did exactly.
Yes I do need the middle curve.
OK, this works. I saw a problem earlier that went away… I like @HS_Kim’s solution better though.
solid_from_loft_2020Dec21b.gh (37.0 KB)
