hi, m new to rhino common, and wrote a ghpython component to extrude a curve both direction to get a closed brep, but the volume of brep is a negative value. please help.
Rhinoscriptsyntax:
if rs.IsCurvePlanar(crv) and rs.IsCurveClosed(crv):
normal = rs.CurvePlane(crv)[3]
crv = rs.MoveObject(crv, -normal * left)
a = rs.ExtrudeCurve(crv, rs.AddLine([0,0,0], normal * (left+right)))
rs.CapPlanarHoles(a)
Rhinocommon:
import Rhino.Geometry as rg
isplanar, plane = crv.TryGetPlane()
if isplanar and crv.IsClosed:
normal = plane.Normal
crv.Translate(-normal * left)
a = rg.Extrusion.Create(crv, left+right, True)
ExtrudeBothSides.gh (7.3 KB)
thank you very much. but what’s wrong with my codes. still don’t know why get negative volume.
You breps solidOrientation was inward, you need to flip them:
so = x.SolidOrientation
if (int(so) == -1):
x.Flip()
a = x
SolidOrientation.gh (7.4 KB)
Thanks for the quick reply. After i bake the brep to rhino, the volume is positive. The solid orientation is only in rhino common?
As far as I know, rhinoscriptsyntax
always creates outward
breps, So you don’t need to check it manually:
Thank you.
