when i try to closecrv this open sided rectangle it ends up making a triangle. It used to just close the curve now it moves the end point. Any help on what to do to fix this command, thanks
Hi Connor - there is a command line setting for tolerance - add a new line or pull the ends together. But you need to post-select to see the options.
“post-select” meaning you start the command without anything selected - then you get the options pascal mentioned - “close Wide Gabs with a line” = Yes, Tolerance = 0.001, then pick the curves kind regards -tom
Thank you both so much! as a rhino novice you saved me a lot of time as I have been manually having to close hundreds of these rectangles. Thanks Tom and Pascal for your speedy responses.
