Clone created dwg file is not imported
Hi there,
so I got an dwf which was created by Bricks Cad and Rhino even doesn`t show the dwg on the import window. When I try with drag and drop, the command line says, the import is blocked.
McNeel Wiki comments as follows:
So, what do I need to do, when a file was created by another dwg clone Cad?
This is entirely missing there.
Thanks.
You mentioned DWF, that is Autodesk’s format for web display. It is incompatible with most applications. You need DWG or DXF.
GstarCAD and Vectorworks indicate they can import DWF, I suppose you could get a trial to see if that will work.
Sorry, thats been a typing mistake. Its a dwg.
Can you share the file?
No, sorry. Totally strictly confidential.
Interistingly my contact at the shipyard was able to open it on R7. He saved it as 3dm and sent it over.
But still a hint what to do with Clone dwg`s would be necessary on the Wiki page.
Without an example file there isn’t much to go on. We don’t even know if it opens in autocad.
I wonder if the DWG import component is disable for some reason?
Although that would not explain if other DWG files are importing.
Alternatively, the error message on the command line displays “import is blocked” as Andre indicates. Perhaps the file is on cloud or network storage? The file may be blocked on the local drive as well.
I have downloaded the file from their ftp server. So it`s local.
But indeed I can’t any other dwg nor is the dwg import extension visible in the list of extensions. And no matter, what I do, the dwg plug in fails to load. I deactivated the bongo plug in, as I don`t have the latest WiP version downloaded. I also started Rhino again and again after setting the plugin to load. But it doesn`t.
I can import other dwg`s though after enabling the plugin. But after a restart it fails to load again.
So there are two problems here. I cant open the dwg`, which is solved by the yard. Fine so far, only the Wiki page should be updated.
But also the import plugin fails to load at the start. Any ideas?
Thanks so much,
André
Do you have Window Smart App enabled? That can block plugins (pre 8.36)
Please run the SystemInfo command in Rhino and post the results.
Not sure what window smart app is, never heard of that. I`m running Win 10 still.
Below the systeminfo from Rhino:
Rhino 8 SR35 2026-9-8 (Rhino 8, 8.35.26251.13001, Git hash:master @ 3645d710f50175d8ebcf404aded5b042a481c23e)
License type: Commercial, Build 2026-09-08
License details: Cloud Zoo
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 80GB)
.NET 8.0.31
Computer platform: DESKTOP
Primary display and OpenGL: AMD Radeon RX 6800 (AMD) Memory: 16GB, Driver date: 8-17-2026 (M-D-Y). OpenGL Ver: 4.6.0 Compatibility Profile Context 26.8.1.260806
Accelerated graphics device with 7 adapter port(s)
  • Windows Main Display attached to adapter port #0
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60
Driver Date: 8-17-2026
Driver Version: 32.0.21045.5002
Z-Buffer depth: 24 bits
Total Video Memory: 16337 MB
F:\Rhino Updates + Plugins\boltgen.rhp “Rhino.NET SDK” 0.0.0.0
C:\Users\merde\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\byRhinoGadget\1.6.1\byRhinoGadget.rhp “byRhinoGadget” 1.6.1.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.35.26251.13001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.35.26251.13001
No security issues with the file noticeable.
I needed to blend out the file path for confidential reasons.
With what exactly? we don’t know what is going on, we need an example file to look at.
BricsCad is also a member of the ODA, we both use the same SDK to build the dwg import export plugins.
So it should work flawlessly. The strange thing is here, that my colleague at the yard was able to open it instantly and save it as 3dm. So the file should be ok.
There are no hints at all on the Wiki page how to deal with such files.
If you know there can be issues, you should also give a hint how to proceed.
we don’t have any known issues in this regard. We do need to figure out what is happening in your case.
Have you tried a repair install of Rhino? Go to add and remove programs and modify then repair your install.
