Tom_P
December 14, 2023, 9:33am
1
referring to this Example / Feature / Tutorial
Using the given file everything works as shown / expected.
But building an example from scratch - I do
not manage to
get auto-naming of the clippingplanes when
_array them
C_00, C_01, C_02, …
what condition / option has to be set to get the names numeric part being incremented ?
can 't find anything in the help (neither clippingplane, nor array command)
thanks. kind regards - tom
wim
(Wim Dekeyser)
December 14, 2023, 9:41am
2
It seemed to have worked doing it like this:
Hi Xeon -
I created a clipping plane using the ClippingSections command and changed the default “SEC” name to “C”. I then used the Array command to create copies of this clipping plane. That seemed to add the correct suffix to the names:
[image]
Are you taking different steps?
Tom_P
December 14, 2023, 10:07am
3
I tried different names for the clipping plane. - no success.
Even if I copy the clipping-plane from the sample-File to a new file, it does not get named “incremental” any more when arrayed.
Tom_P
December 14, 2023, 1:17pm
4
was anybody able to repeat the workflow from the tutorial in a blank document, units millimetres ?
for example:
new document
clippingPlane → name it C_01
array (nx = 1, ny = 1, nz = 20)
thanks for you comments
Tom_P
December 21, 2023, 11:00am
5
@pascal or @Gijs
does this auto-naming of Clipping Planes work for you - or anybody else - in a new file. I don t get it to work. thanks for an update
Tom_P
December 22, 2023, 4:19pm
6
just wanted to say, this is somehow a presales question from a customer. Just told him to be patient and stay with Rh7.
pascal
(Pascal Golay)
December 22, 2023, 4:21pm
7
Hi Tom - I’ll give it a try.
@Tom_P - the Array command never will change the name - (not a bad idea perhaps, but it does not) I think what you are after is SectionPlaneArray
Tom_P
December 22, 2023, 4:47pm
8
thanks for having a look.
the description of above tutorial / feature-introduction claims:
can you repeat the above tutorial on a blank file ?
for
SectionPlaneArray
I do not get a autocomplete in the commandline
(Version 8 (8.2.23346.13002, 2023-12-12) on mac intel)
pascal
(Pascal Golay)
December 22, 2023, 4:51pm
9
@Tom_P - sorry for the confusion - my fault. If the clipping plane is created from ClippingSections
, it has more smarts and the array naming works. This is not explicitly mentioned on that page, that I can see… I’ll see if we can make that clearer.
WWW-2303 Tune up to Sectioning web page
Tom_P
December 22, 2023, 5:07pm
10
Pascal Golay:
more smarts
… and…
…but this spicy “smartness” is lost when copy-paste between 2 documents ;-(
maybe update the above feature-introduction / tutorial. - quite sure somebody else will fall in the same trap.
… yep I see your edit…
great - thanks - have a nice Xmas - kind regards -tom
wim
(Wim Dekeyser)
December 22, 2023, 7:34pm
11
Hi Tom -
Sorry that this thread got buried under all other traffic…
In the post that I referenced, I wrote:
At any rate…
I’ve put that on the list as RH-79315 ClippingSections: copy-paste removes special characteristics
