"ClippingDrawings" Suddenly produces No results Except Sec_00 Label
Using Rhino Version 8 – “ClippingDrawings” command suddenly produces No results Except “Sec_00” , and, just as I attempted to place the desired 2D result in the square in the background, oddly, the label jumps to 0,0.0 Additionally as can be seen in the image attached I selected the “SEC_00Drawing” layer, and others, in the layers panel, then right clicked to “select objects” in the layer and it reports No objects added to selection. Confirming nothing was produced, except the Label?
I’ve attempted this on numerous files that were producing results yesterday and likewise I get no results? Any help would be appreciated. Today was to be dedicated to creating clipped Drawings and I’m at a complete loss as to how to fix this? Thank you.
2d Missing.3dm (93.3 KB)
@Fred_Tholke Is this still an issue?
If so, what version of Rhino are you using?
This is what I get when I run ClippingDrawings (with Background=True) using version: 8.34.26202.13001, 2026-07-21
