Clipping Sections - Layer Control with Linked Blocks
I am an architect using the current WIP version of Rhino and having an issue with clipping sections and project documentation.
We find it the best way to manage an architecture project is to have a “central model” file where we do all of modelling, but nothing else. This keeps file sizes small and organized. It also then allows us to insert the model into various “documentation files” that have unique section styles set up for the type of drawing we are making. This way a 1/4" plan drawing can read as having solid gray fill in the walls and a 3" detail can show hatches appropriate for the building materials. We insert our “central model” into our “documentation files” as a linked block with active layers.
The issue arises when we implement the clipping sections. We do this based off of layer properties and are getting the desired effect in our drawings however we cannot exclude certain layers from the clipping section because the program is just reading all of those layers on single layer the block is located on. This results in extra information showing up in our drawings we can’t eliminate.
We see this being fixed potentially in two different ways:
  • Layers: We can toggle the visibility of each layer based off of the active layers in the inserted block so it seems that the code in Rhino should be able to have the clipping sections “read” those layers rather than the layer the block is located.
  • Clipping Drawing boundary (XCLIP) : The other way we could see this being improved is if we could restrict the boundary of the clipping drawing like the XCLIP command works in AutoCAD.
I have attached a diagram of our file management for reference.
Studio Nocturne Rhino Workflow Diamgram.pdf (407.7 KB)
I am also attaching reference screen grabs:
Hi Neal -
I’m not sure how you are dealing with the section styles for objects in the block, but I see the issue with excluding layers not working.
→ RH-98777 ClippingDrawings: Doesn’t Exclude Excluded Layer in Block
Note that this seems to work with Worksession in Rhino 9, though.
The blue box is geometry in an attached file and excluded from the clipping plane.
The resulting clipping drawing does not show that blue box.
Hi Wim,
Thank you for looking into this topic.
My commentary about active linking a 3d model into separate “documentation” files with separate section styles, tailored for different scaled drawings, was only included to explain why use case why we are looking for this functionality. Our only ask in this post, is if the program can be updated so that clipping sections can exclude layers of linked blocks.
We have a small team that needs to work simultaneously on projects (some updating the 3D modelling geometry in our “central file”, while another team member updates the annotations, dimensions and schedules in our “documentation file/s”). This is why we need separate files with an active block link vs being able to utilize the worksession functionality.
Thank you,
Neal
RH-98777 is fixed in Rhino BETA
