Dunno, Age of Ultron (the movie) doesn’t promise much good from super powery persons.
WISH: Similar to the bolt unclipping example,
but if there was way to clip surfaces and not the wires that’d be nice.
When trying to close a surface and many details are behind surfaces ghosted mode doesn’t work and wireframe can’t get the correct surfaces.
I use clipping to get to that hidden parts, but If i can see the wireframe of the whole content it helps to identify the surfaces.
Yes indeed. USUALLY implementing only at MAJOR releases is reserved for NEW features, not corrections applied to existing features.
-Chuck.
Wonder if cross-linking here will do any good, but I was recently on a hunt for a way to toggle individual clipping planes, but toggling them all would be nice too:
(Either that or a way to simply flip/flop between two commands every other time you click on a button, but that’s outside of this topic…)
Thanks, yes I saw that and tried it, but unfortunately didn’t like it. I want the toggle button in a custom toolbar, and when I placed your script in a custom toolbar, the popup menu jumped around between clicks (and unnamed clipping planes displayed a bit weird).
What I did now is simply put this in a button:
! _SelClippingPlane _Pause
_PropertiesPage _ClippingPlane
That still means an extra click for me, but it felt more stable.
Thanks McNeel team for adding the fill on closed sections. This is very useful for imported geometry w/naked edges, or scanned data.
I do not see an option for hatch fill like shown on the youtrack, it’s not implemented yet, correct?
thx,
G
Hi Gustavo -
That is implemented.
Look for the “Section Style” pulldown on the Properties
panel or the column with the same name on the Layers
panel.
Hi Gustavo -
Not from only those two pictures, I’m afraid. Can you post a simple model that I can take a look at?
Thanks,
Looks like you’re setting the section fill for the clipping plane. This means you’ll need to set objects in the scene to use “By Clipping Plane” for their section styles.
You can also select objects themselves and set their section styles to custom.
hi Travis, Wim,
IO tried both ways: setting it by clipping plane and by object, but still I cannot see it. attached file.
clipping_plane_missing_hatch_01_gf_220823.3dm (3.0 MB)
Thanks,
G
Select the sphere and cylinder and set their Section Styles to By Clipping Plane.
Then zoom in to see that crazy small hatch
Then go back to the clipping planes section style and increase the hatch scale from .1 to 10
HI Trav, I just tried that. Making a video to make sure I’m not doing it wrong:
I tried various scale levels and nothing happens.
When I changed the hatch type to solid, this weird thing happened:
Here’s my system info just in case:
Rhino 7 SR21 2022-7-27 (Rhino 7, 7.21.22208.13001, Git hash:master @ c31aea87137a5d0de449338a7ef6856f49dd4797)
License type: Commercial, build 2022-07-27
License details: Cloud Zoo
Windows 11 (10.0.22000 SR0.0) or greater (Physical RAM: 1.3e+02Gb)
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce RTX 3090 (NVidia) Memory: 24GB, Driver date: 6-6-2022 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 516.40
- Secondary monitor attached to adapter port #0
- Windows Main Display attached to adapter port #2
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-6-2022
Driver Version: 31.0.15.1640
Z-Buffer depth: 24 bits
Total Video Memory: 24 GB
C:\Program Files\Bongo 2.0 (64-bit)\Rhino6\Bongo.20.rhp “Bongo 2.0”
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\GustavoFontana\AppData\Roaming\McNeel\Rhinoceros\7.0\Plug-ins\OctaneRenderForRhino (f109bd23-4cf3-4c0b-9f83-06be474b0152)\2021.1.4.132\RHI Installer 7\Rhino 7.0\x64\OctaneRenderForRhino.rhp “OctaneRenderForRhino” 2021.1.4.132
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RPC.rhp “RPC”
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.21.22208.13001
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.21.22208.13001
Any thing else I can try?
G
Here’s what I’m getting
What happens if you leave the clipping plane section style to By Layer and then just set the object properties section style for the objects to something like grid at scale 10?
Hi Gustavo -
I see from your video and 3dm file that you are running the current Rhino 8 WIP but, just to make sure, could you post your SystemInfo
from Rhino 8?
Have you customized your display mode? What happens if you test with vanilla wireframe?
