Clipping Planes - Locked Blocks Issue - 8.19
Hi @rajaa, @Gijs, and @wim,
Is this repeatable on your end? It seems that when I have a clipping plane in my scene and I have locked blocks, the clipping gives me z fighting and “poches” the entire block instance.
If I unlock my scene I have no issues with the blocks.
Locked:
Unlocked:
Thanks for your help!
@michaelvollrath I don’t see it. Can you please share the simplest example you can extract out of your model and share here? Also please share which version and SR are you running.
This is what I see, unless I’m missing what you means:
Hi @rajaa,
Sorry I can no longer repeat the issue in my original file or a test file… I must have bugged the conduit and a restart fixed it.
EDIT: actually it appears to be related to Display Pipeline and a Custom Display mode because I can only trigger it when using a specific display mode. I’ll report back if I can narrow it down to a bug and not user error in my pipeline code
