Clipping planes is offset
Using the beta on windows.
I am having some odd results with clipping planes. with a top view clipping plane active in top and perspective. the plane is offset by some distance between the two view, ( clearly not cutting at the same level )
everything is square and parallel to the construction planes. Const planes are in default ( world ) position.
any tips??
thanks
Hi Sachs -
Please post both the output from the Rhino SystemInfo command and a 3dm file that illustrates this issue.
rhinoSysRep_SACHS_20260807.txt (2.2 KB)
Model file it too big to upload. As in the screen shot, volumes are clipped at a different level in the top view relative to the other views.
LMK if I can send the model file another way.
Hi Sachs -
Please use https://www.rhino3d.com/upload/ to upload the file to us. Make sure to copy a link to this discussion in the “comments” field on that page.
