Clipping planes disappearing
I have a clipping plane that has disappeared from model space but is still active in my details. I cannot see it or select it, but when I enter a detail I can selected it using SelName. All the properties come up like normal in the sidebar but if I change back to model space it is not visible. Since I selected it in the detail it remains selected (but invisible) in model space. I can even enable the clipping plane to clip geometry in the different model space views.
I have confirmed the layer visibility is on, and that the clipping plane hasn’t been hidden.
Actually tried one more thing as I was writing this: By activating the layer that the clipping plane is on, it reappeared in modelspace….
The missing clipping plane is now acting like normal.
Seems like there could be a weird display pipeline bug that caused the clipping plane to disappear and not get re-rendered.
Per your other thread..
Let’s update your video driver to the latest. When installing choose Custom and check the clean driver install option
link to the latest Quadro RTX 3000 Driver
I’m due for a clean reinstall of windows. I’ll make sure IT updates the drivers too and will report back if that solved both of these issues. Thanks
