Clipping plane
Hello All,
Rhino newbie here, i am having trouble using the clipping plane. i saw a lot of video where their clipping plane got the axis point to move around and rotate the cliiping plane. somehow mine only got the wireframe box and a line pointing to the section area. and unable to rotate the clipping plane. did i miss some setting somewhere?
appreciate the help from yous expert
You might not have the gumball widget turned on. If it is on , click on the colored arc lines to get started.—-Mark
Hi -
Apart from what Mark wrote (and which is probably what you are looking for), you can always rotate and move a clipping plane with the regular Rotate and Move commands.
thanks man, exactly what i was looking for.
appreciated it
noted. it works also. thanks
