I am plotting two rendering viewports to PDF on two different levels. I have one block (repeated several times) that should be sectioned in both levels. Level 0 works fine. Level 1 works in some but it does not work in some of the instances.
Level 0
Can’t replicate with a simpler file.
but, in trying it, I also noticed is that the background shade (it is a rendered view) is limited to around the geometry and abruptly ends ( I am not sure it is visible in the image - the blue rectangle is the tiling image selection in acrobat, there to try to highlight the bottom limit of the background shade.
N
