Clipping Plane not work well V6
It does not work well with the solid option enabled. In v5 it works well, in v6 not.
In addition, by moving the clipping plane will not instantly updates the section line on object,
that is, while you drag the plan does not instantly update the section. (this also works well in v5).
Hi Davide- thanks, but it is not actually of much use in tracking down the problem without an example file.
I’m waiting for send me the 3dm files, I do not own the wip, I can not test unfortunately.
Thanks
Why not? If you have a licensed v5, you can download the WIP and play.
I would wait for the final release of Rhino 6 to buy an educational license.
