For whatever reason, the model I was working on all of a sudden was sectioned down to a small sliver of the total project. To be clear, the way the model is being sectioned off it appears to be a clipping plane or clipping section from both ends but disabling either of those yielded no results. I closed and reopened the file but whatever error or view style this is remained. Any ideas?
Can you run the SystemInfo command and post the results? We’ll probably need to see the model too.
– Dale
I don’t know what happened but eventually changing the view made everything ok. Strange bug. Thanks.
