Hello, I am having some issue with the Rhino Clipping Plane. On every display mode except “Shaded” I am noticing some kind of overspill, where the object is being cut. I tried adjusting the tolerance, however it didn’t seem to make any difference. Any ideas to solve the issue are much appreciated.
Hi Marlon-
Can you share the model in question? We’d like to see if we can reproduce this on our side. If you can’t share it publicly here, can you use our private uploader? Feel free to use dan@mcneel.com and just paste in the Discourse link here into the comments.
It would also be helpful to see the output of the SystemInfo command so we can get the exact version of Rhino you are using.
Thanks,
-Dan
