Hello everybody!
is it possible to change the thickness of the contur/outlines generated by the clipping plane for the cutting objects? Currently the color of this outline is given by the clipping planes layer (as shown in the picture - green outline). Sadly the display of the contur of the cutting object is somehow not controlled by the layers linetype. If you`d create a new linetype and set it to the layer, where the clipping plane is on, nothing in the display of the cutted objects change?!?
Thank you for reading and probably an answer ;=)
