This is an around 12 meter long quite detailed model with many, many parts that I’m clipping straight across. When the view gets close to the clipping plane, that happens, and it stops when I zoom out (the red lines at the end are the colors of my clipping plane).
Sometimes, I even get a large, solid colored rectangle covering the entire clipping plane, ruining my view as well. I’m going to switch back to V6 now to see if it goes away or not…
EDIT: I now edited the file for an hour in V6 and no flashes at all. Switched to V7 and it began flashing within a few minutes of loading the file… attaching my view mode in case it makes a difference…
Well… I switched to a different PC now and that particular problem went away… (another reason to order a new PC with the 3090, I guess).
However, I have noticed that regardless of display mode, some objects refuse to get selected unless you really change the camera/zoom drastically… with some angles, some objects simply refuse to get selected…
