Clipping plane casts shadows in customized display mode
Hello, I’ve followed this tutorial (https://youtu.be/T4n6eDyXHLc) to create a customized display mode where shadows are clearly defined. However, whenever there’s a clipping plane (even if it’s hided) it casts shadows, which makes the drawing very confusing. How could I avoid this while still having the shadows of the section?
Dear @Gustavo10
i was not able to repeat your issue on a mac intel.
please post more details:
  • upload the rhino / 3dm file
  • upload your systemInfo (command _systemInfo → save as file and upload)
  • export and upload your display Mode, in _options → display mode → select your custom display mode, below the list their is a gear icon that will allow you to export it.
make sure your system and rhino have the latest updates.
what rhino version are you using ?
kind regards -tom
Hi, thanks for the reply, here’s the info you ask for. I’m using rhino version 8.26.25349.19002 in macOS Sequoia 15.7.3 (24G419)
Shadows.ini (7.6 KB)
System info.txt (4.9 KB)
Shadows.3dm (53.5 KB)
sorry can not reproduce - but i am on a intel, mac os x ventura 13.7.7
Ok here on an M1.
Running the Reset command would be the next step.
Thanks for the replies. I ran the factory reset command and nothing changed. I’m on an intel mac (if it’s of any help).
