clipping plane caps open polysurface.3dm (2.8 MB)
This looks like a bug because open polysurfaces should stay open when clipped by the clipping plane.
Please check. Thank you!
Hi Bogdan -
This was changed in Rhino 8 based on user requests. When a section creates a closed curve, the section can be shown as capped.
Changing any of the following will turn that off:
(1) By default, the display modes are set to use section styles.
(2) By default, the section style that is assigned to all layers are defined with “Section open objects”
(3) By default, all objects use the section style that is assigned to their layers
hi @wim
where can i find these settings ? thanks!
Hi Bogdan -
(1) Rhino Options > View > Display Modes > [your_mode] > Objects > Clipping Planes > Use section styles // Use fills
(2) Layers panel > Section Style column > Section open objects
[In Rhino 9, you can create a section style in the Document Properties and assign that to multiple layers. In Rhino 8, you can select all layers and change the initial “None” style into a common “Custom” style.]
(3) Properties panel > Section style > Custom
The fourth way of doing things is as you show.
When you set the section style of a clipping plane, you will also need to set the section style of individual objects to be by clipping plane instead of by layer or custom.
I think there are inconsistencies. The red polysurface should not be capped - but it gets capped
i think the user requests were bad in this situation.
oh, yes… i understand now… thanks
