Clipping plane aware calculation tools
When we use commands such as length, area, volume… on a clipped object, it should calculate the clipled section.
For example, when you run the length command to measure the edge of a box like below, it gives the entire edge length instead of 2m.
When you measure the area of the front face, the area command gives the area of the entire surface instead of 6m².
