I can make the clipping fills of 3D closed surfaces (meshes and NURBS) show in the rendered viewport. But when I render an image via the Rhino Render, the fills are gone.
Did I miss out on a setting or is this impossible?
That is currently impossible, yes.
Of the McNeel renderers, only Brazil will take the ClippingPlanes into consideration as they should.
Thanks! This means a LOT of ‘cut’-ting and ‘cap’-ing then.
Well, …
For me it just means that it is not possible. Saving a copy of the file to do all the cutting and capping, make a few design changes and go through all that once again - no thanks, life’s too short.
I’ll have to make do with screen shots for the time being.
