Am I missing something about the command line options for the ClippingDrawings or are the AddHiddden [Yes|No] and AddSilhouette [Yes|No] options not available? I do not have the options on the command line and do not know how to invoke them? Any help would be greatly appreciated. Thanks in advance. Cheers!
Hi Mike -
I’m getting the following options when I run that command:
( Angle=0 ShowHatch=Yes ShowSolid=Yes AddBackground=Yes Projection=Parallel AddHidden=No AddSilhouette=Yes ShowLabel=Yes LabelStyle=Text ApplyToAll=No )
Please run the Rhino SystemInfo
command and copy-paste the result here.
Thanks for taking a look:
Tried again, still not getting the option for AddHidden or AddSilhouette . . . ?
here is the SystemInfo:
Rhino 8 SR3 2024-1-9 (Rhino 8, 8.3.24009.15001, Git hash:master @ 3541fa287a013b0f17849f0740f1e43a44031bfc)
License type: Commercial, build 2024-01-09
License details: Cloud Zoo
Windows 11 (10.0.22621 SR0.0) or greater (Physical RAM: 64Gb)
.NET 7.0.0
Primary display: Intel(R) UHD Graphics (Intel) Memory: 1GB, Driver date: 7-11-2023 (M-D-Y).
- Secondary monitor attached to adapter port #2
Primary OpenGL: NVIDIA RTX 5000 Ada Generation Laptop GPU (NVidia) Memory: 16GB, Driver date: 6-26-2023 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 536.45
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 6-26-2023
Driver Version: 31.0.15.3645
Z-Buffer depth: 24 bits
Total Video Memory: 16376 MB
C:\Program Files\Scan&Solve Pro for Rhino 6 & 7\SnSPro_Rhino_6+7.rhp “Scan&Solve Pro for Rhino” 1.0.0.0
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.3.24009.15001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.3.24009.15001
These are the options I get:
Command: _EditClippingDrawings
Editing SEC_A02CFloorPlan01_00. Press Enter to accept ( Angle=0 PlacementPoint AddBackground=Yes Projection=Parallel ShowLabel=Yes )
Command: _CommandHistory
The AddHidden option has been added to SR4. Please update to the latest service release, and you should see it.
Thank you that seems to have worked. I tried to update the day I posted the first inquiry but it returned that Rhino was up to date, I even tried switching to Release Candidate . . . ? well thanks for the quick assistance. Cheers!
