I have 2 objects in my model - one on layer A, and one on layer B.
I create a Clipping Section and Drawing.
I set the Clipping Drawing to “Include Selected”.
I select both objects - my clipping drawing displays two objects.
I select only Layer A to be included. The clipping drawing still displays two objects.
Even if I select no layers, both objects are still displayed in the clipping drawing.
I would assume the Objects and Layers selection should work as an “AND” filter - eg if I select both Objects, but only one Layer, then only one object should show up in the clipping drawing. (the one on the included layer)
Can you confirm that this is how the clipping drawing “include selected” functionality should work? And will this be fixed?
The upshot of this is - we can’t use Clipping Drawings with Blocks or Groups. Because you can only select the whole block or group as an object, and the layers functionality doesn’t work, you can only display all the layers of the block or group (which makes it unusable)
This issue is specific to Clipping Drawings used on Blocks containing multiple Layers.
Because a Block is one object, and is nominally on one layer (even if it contains multiple layers within it), the Clipping Drawing cannot distinguish the layers within the block.
Eg, when I insert a Block on the Default layer, the only layer that affects the output of the clipping drawing with “Include Selected” mode is the Default Layer. You cannot exclude different layers contained within the block.
It would be extremely helpful to be able to generate a clipping drawing only using specific layers from within the block - is this possible?
The use case is where one person is modelling in a “Model” file, and another person is drafting in a “Sections” file (cutting sections from the Model file using clipping drawings, and only displaying certain layers).
The “Model” file is inserted as a block into the “Sections” file. We would like the clipping drawing in the Sections file to only generate / display certain layers from the Model file block. However this is not possible due to the above issue.
The issue is the same even if they’re not separate files eg creating a clipping drawing from a block within the same file.
With Include Selected, the object list and the layer list add together. An object is included if it’s in the object list or its layer (or a parent layer) is in the layer list. Clipping planes work the same way in the viewport, and the clipping drawing follows the clipping plane. If both objects are selected, both are drawn, whatever layers are checked.
With a block instance, the include test runs on the instance as a whole, using the layer the instance is on. When the instance is included, all of its contents come with it. The layers of the objects inside the block aren’t checked.
Exclude Selected checks those inner layers. To get only some layers from your inserted Model file:
Select the clipping plane and open the Properties panel.
Change the participation mode from Include Selected to Exclude Selected.
Add the layers you don’t want in the drawing (the layers used inside the block) to the layer list.
Make sure the block instance itself isn’t in the object list.
The objects inside the block that are on excluded layers are then left out of the clipping drawing. Everything else in the block is still drawn.
