Vaker
June 8, 2020, 8:03am
1
Rhino6 show the end points automatically after clicking line.
I want add end points and display in red and green.
The end points created by clicking line will cover the red and green end points which I added.
We can not show the red and green end points in view.
How do I fix the problem?
wim
(Wim Dekeyser)
June 8, 2020, 10:39am
2
Hi -
I probably don’t understand the problem completely but does it help to turn off the Turn on control points when selecting a curve, light or annotation
in Rhino Options > Mouse
Vaker
June 9, 2020, 1:11am
3
Hi Wim,
It works, thank you.
What function can disable this option?
Kindly regards,
Vaker
wim
(Wim Dekeyser)
June 9, 2020, 6:40am
4
Hi Vaker -
I take that this means that you want to be able to set that with code.
You should be able to run the following macro from within your program:
-Options Mouse SelectionAndMiddleButton AutomaticPointsOn=No EnterEnd
Vaker
June 10, 2020, 3:52am
5
Hi Wim,
I want to check the “AutomaticPointsOn” option “Yes” or “No” before run the macro.
How to do with code?
or change “AutomaticPointsOn” = “No” by another way (not runscript)?
I do want to run the macro every time.
Kindly regards,
Vaker
wim
(Wim Dekeyser)
June 10, 2020, 8:04am
6
Hi Vaker - I don’t know if there is anything in RhinoCommon for checking or setting this option.
@dale , could you provide more information here?
dale
(Dale Fugier)
June 10, 2020, 2:54pm
7
Hi @Vaker ,
How about this?
CRhinoCommand::result CCommandTestVaker::RunCommand(const CRhinoCommandContext& context)
bool bAutomaticPointsOn = RhinoApp().AppSettings().GeneralSettings().m_bAutomaticPointsOn;
if (bAutomaticPointsOn)
CRhinoAppGeneralSettings settings = RhinoApp().AppSettings().GeneralSettings();
settings.m_bAutomaticPointsOn = false;
RhinoApp().AppSettings().SetGeneralSettings(settings);
// TODO...
settings.m_bAutomaticPointsOn = bAutomaticPointsOn;
return CRhinoCommand::success;
– Dale
Vaker
June 11, 2020, 7:53am
8
Thanks for @dale , @wim help.
I can fix my problem now.
Kindly regards,
Vaker
