Hello. I am starting to model in 3D with Rhino and have rapidly found that the model becomes very messy with additional lines. In particular when using the boolean commands. I realise that the model can be viewed with the shaded setting to ‘clean’ this up and that some of the lines that indicate a surface can be removed but it is more to do with the lines that are left when changes are made. I am very used to the Sketchup logic of creating solid shapes and how easily Sketchup cleans away unwanted lines (or how easy it easy to manually remove them). Is there a workflow that I can use to tidy up the geometry?
Hi Jake -
When you don’t post a 3dm file that demonstrates an issue, you have us guessing at what’s going on. Perhaps MergeAllCoplanarFaces works? Or ShrinkTrimmedSrf? Or you want to turn off an object’s isocurves?
Fair point. I think it is to do with going back in to a polysurface shape and adding gometry. In the attached model I have used booleandifference to make a gap and if I were to now fill it in or rationalise the irregularities, the line command seems like a very clunky tool to use to do the job. Is there a quicker way to add surfaces and then delete away the unwanted lines?
Example model.3dm (122.5 KB)
It is merely an example of a situation where lines need to be altered. I take it that means that I can’t go back in and adjust and delete lines?
No, you are working with surfaces, not lines. Certainly it’s possible to clean up the mess, but it’s a lot easier in this case to just draw a new box and cut the opening correctly with a curve (on Layer 01) - about 30 seconds work max.
Example model-msh.3dm (2.7 MB)
I’m a recent convert from AutoCAD. With any new software it pays to work out how the software does things rather than trying to force your existing workflow on to it. I’m a great fan of Rhino. There’s a lot that I feel it does better than AutoCAD, but there’s still the odd AutoCAD feature that I miss.
The best approach would be work out the most effective way to achieve you task in Rhino, not to try and force an existing approach which may be far less efficient in Rhino.
