Download the latest Service Release of Clayoo 2.5, available since December 12th on your User Area.
Grasshopper components added and minor bugs fixed in this update. Improving for a better user experience.
How to Download (Only available for Clayoo 2 Licensed users)
- Sign In › Dashboard › Software Installers
If you want to try Clayoo, register on https://www.tdmsolutions.com/register/ or contact us at info@tdmsolutions.com.
Update details
› General changes
- User Guide: updated to the latest version.
- Release Candidate default value set to False (deactivated).
- New analytics to collect data implemented.
- Clayoo is now uninstalling the previous version in silent mode.
- _ClayInset: changed the RUI string in Spanish from _ClayIncrustación to _ClayInserción.
› SubD
- Changed the object type from Clay Surface to Clay Object.
- Fixed a bug where turning off Clayoo set the scene basic/smooth mode general, not by object.
- _ClaySphere: fixed a bug when radius = 0.
- _ClayCone: fixed a bug where in Korean was not working.
- _ClayFromCurve: fixed a bug where negative values were not allowed.
- _ClayFromCurve: fixed a bug where invalid inputs were not opening the UI.
- _ClayLoft: added an option to close the loft from the last to the first profile.
- _ClayBlueprint: size by default readjusted.
- _ClayBlueprint: fixed a bug where align was not correct.
- _ClayDivide: fixed a bug where hidden and locked objects were affected by the tool.
- _ClayMatch: fixed a bug where aligning into a closed curve had two points to align.
- Fixed a bug where materials in some display modes were wrongly displayed.
- Fixed a bug where Record History was not always working with Clayoo gumballs.
- _ClayWeld: fixed a bug where using weld with a selection mode different than vertex was not requesting for the second selection.
- _ClayBridge: bridge align has been updated to be more useful in complex shapes.
- _ClayShell: fixed a bug where shell was not generating geometry in some cases.
- _ClaySymmetry: fixed a bug where joining parts had issues with the gumball.
› Grasshopper
- GH Clay Convert Mesh component added.
- GH Clay Loft component added.
- GH Clay Revolve component added.
- GH Clay Sweep component added.
- GH Clay Decompose Edges component added.
- GH Clay Decompose Faces component added.
- GH Clay Decompose Vertices component added.
- GH Clay Explode component added.
- GH Clay Draw Edges component added.
- GH Clay Draw Faces component added.
- GH Clay Vertices component added.
- GH Clay Bridge component added.
- GH Clay Delete Faces component added.
- GH Clay Extrude component added.
- GH Clay Inset component added.
- GH Clay Shell component added.
- GH Clay Weld component added.
- GH Clay Window component added.
- GH Clay Box component added.
- GH Clay Cone component added.
- GH Clay Cylinder component added.
- GH Clay Ellipsoid component added.
- GH Clay Plane component added.
- GH Clay Sphere component added.
- GH Clay Torus component added.
- GH Clay Truncated Cone component added.
- GH Clay Object component added.
- GH Clay Selection Indices component added.
- GH Clay Basic component added.
- GH Clay Smooth component added.
- GH Clay Mesh Smooth component added.
› Emboss
- Fixed a crash adding curves to the Resources Manager from the right view.
- Fixed a crash using Texture Builder.
- _RasterToVector: size by default readjusted.
