@scottd , since this discussion started about credits, and i also see some tasks consuming a lot more than others, can you introduce in this AI panel some overview for the credits?
Like, how much credits are left, how much credits each tasks consumes.
This is something missing in the desktop apps, and it can give us essential information about our AI usage.
The Desktop version of Claude Cowork does that, but I do not think Astra does. I will get it on the list of requests.
Managing tolken usage is going to become a really big deal. Trying to make productivity efficient will take some time and engineering. Also, as the Ai framework evolves that will change what is possible.
There are desktop widgets that chart tolken usage realtime.
Then why does my question about credits has different answers?
Inside the desktop app i get a correct answer, while in the ai panel it can’t answer my question at all.
RhinoAi is not an LLM, its a particular access to your LLM accounts via its local cli app.
There are three layers: The rhinoAi panel, the local cli app, the cloud LLM. Putting a prompt into the panel uses the tools i screenshotted, hence you can’t run Bash, Grep, /usage, etc, you can only call the Rhino MCP tools and any extra MCP servers you added here..
There is some information on usage that comes with the response from the llm that could be passed, its going to differ with the model you use. That is what the feature request covers.
The RhinoAi panel can do a lot but is essentially training wheels for accessing Ai in Rhino. Using the Rhino mcp in the CLI app puts you in the fast lane.
@Bogdan_Chipara on the Claude side, the closest thing to the credit overview you asked for is /usage in a Claude Code terminal session: subscribers get the plan-limit bars, d or w switches to the last 24 hours or 7 days, and it splits recent usage across skills, subagents, plugins and individual MCP servers, flagging long context or cache misses when either is 10% or more. It’s computed from local session history on that machine, so claude.ai and other devices aren’t counted. As for why Pro runs dry so fast: the allowance is one pool shared with Claude chat and Cowork, measured in a five-hour window and a weekly window that span all models (switching to Sonnet doesn’t reset anything), and Anthropic doesn’t publish those caps in tokens. Every request also re-sends the whole conversation plus every tool definition, which is Callum’s point above; Anthropic’s own docs put a typical five-server MCP setup at about 55k tokens of definitions before any work starts, so trimming connected servers matters as much as prompt style. On the Codex side, Fast mode draws the allowance at 2.5× the Standard rate, worth checking if one task seems to eat far more than the others. I run aicost.tools and keep notes on how these plan meters work here: How to check Claude Code usage and what it costs · AI//COST
I did try claude , set up was easy going , and after some dissapointing trys , within 1 hour i was out of usage , dissapointing , so no more trys , there must be something easyer and no cost for trying
Can you tell us more about your experience @robo? Is your disappointment with the AI’s capabilities, or the tools it was using? What did you try and what did you expect to happen that fell short?
i did try to get a 2d drawing scan formed in to a 3d object , it was a boat just for trying , but curves where wavy and no good as the 2d side view , the reconition was good but the result not so , also a picture from a plane claude did reconize excatly the model but the 3d result of this was also.. dissapointing it did not look like it , maybe i was expecting to much
