Circles exploding into lines (latest WIP)
also, this line was drawn with co-ordinates 0,0 10,0 (something not quite right though)
If I turn off openGL Tessellation then all is normal again.
hth,
Is your GPU an Intel HD 4000? I’ve seen this behavior only with that specific GPU.
https://discourse.mcneel.com/t/gpu-kachelgrafik-on-intel-4000/?source_topic_id=45214
Hi @KeithR , Can you run the SystemInfo command in the WIP and paste that text here? I bet Steve will need that info too. Thx
SystemInfo.txt (1.4 KB)
Thanks; this sure looks like the same Intel driver that is not working with Rhino’s GPU tessellation feature. I’m going to try and have Rhino detect this driver and disable GPU tessellation when it notices that driver.
I’ve created a bug report to detect this specific driver and disable GPU tessellation in that case.
https://mcneel.myjetbrains.com/youtrack/issue/RH-40027
RH-40027 is fixed in the latest WIP
