Hi all, I’m trying to re-create the bamboo loop element as the reference image. I’m currently facing the following problems.
- While dividing multiple circles (curves) into points, how to select all the same points(as in point no 1, point no. 2, etc till the list end) all at once and interpolate.
- How to define the plane of these interpolate curves to offset it.
- How to control the size of each circle to increase and decrease the radius easily.
- When using the simple pipe command to add thickness to the lines it makes the geometry very heavy when baked. Is there an alternative to it?
- How to align the points on circles such that the interpolate curve doesnt intersect with each other.
TIA
BAMBOO MESH.gh (25.2 KB)
