Hello everyone,
I’m having a problem trying to connect the curves in the red group in OpenNest, to complete the board. There are two circles with a hole for laser printing, but he understands them as if they were separate circles, like the first one. You can see the result before organizing by OpenNest in the green command, and the red arrows indicate what I would like to do, but can’t. Thank you very much in advance for your help.
RG3_Gomo Encaixe Corte a Laser 2 sem X.gh (48.3 KB)
I don’t have old Opennest version anymore, but you can do something like this, splitting your outer curves and inner curves into separate lists
then you nest the outer curves A, and you Transform the inner ones B using (Grafted I guess) transform data from the Core Nesting component:
