hi,
it seems to be quite well documented here :Math | EasyRGB
this might helps, i found some apparently working c++ examples on stackoverflow, that make the conversion in two steps: lab to xyz then xyz to rgb:
// using http://www.easyrgb.com/index.php?X=MATH&H=01#text1
void rgb2lab( float R, float G, float B, float & l_s, float &a_s, float &b_s )
float var_R = R/255.0;
float var_G = G/255.0;
float var_B = B/255.0;
if ( var_R > 0.04045 ) var_R = pow( (( var_R + 0.055 ) / 1.055 ), 2.4 );
else var_R = var_R / 12.92;
if ( var_G > 0.04045 ) var_G = pow( ( ( var_G + 0.055 ) / 1.055 ), 2.4);
else var_G = var_G / 12.92;
if ( var_B > 0.04045 ) var_B = pow( ( ( var_B + 0.055 ) / 1.055 ), 2.4);
else var_B = var_B / 12.92;
var_R = var_R * 100.;
var_G = var_G * 100.;
var_B = var_B * 100.;
//Observer. = 2°, Illuminant = D65
float X = var_R * 0.4124 + var_G * 0.3576 + var_B * 0.1805;
float Y = var_R * 0.2126 + var_G * 0.7152 + var_B * 0.0722;
float Z = var_R * 0.0193 + var_G * 0.1192 + var_B * 0.9505;
float var_X = X / 95.047 ; //ref_X = 95.047 Observer= 2°, Illuminant= D65
float var_Y = Y / 100.000; //ref_Y = 100.000
float var_Z = Z / 108.883; //ref_Z = 108.883
if ( var_X > 0.008856 ) var_X = pow(var_X , ( 1./3. ) );
else var_X = ( 7.787 * var_X ) + ( 16. / 116. );
if ( var_Y > 0.008856 ) var_Y = pow(var_Y , ( 1./3. ));
else var_Y = ( 7.787 * var_Y ) + ( 16. / 116. );
if ( var_Z > 0.008856 ) var_Z = pow(var_Z , ( 1./3. ));
else var_Z = ( 7.787 * var_Z ) + ( 16. / 116. );
l_s = ( 116. * var_Y ) - 16.;
a_s = 500. * ( var_X - var_Y );
b_s = 200. * ( var_Y - var_Z );
//http://www.easyrgb.com/index.php?X=MATH&H=01#text1
void lab2rgb( float l_s, float a_s, float b_s, float& R, float& G, float& B )
float var_Y = ( l_s + 16. ) / 116.;
float var_X = a_s / 500. + var_Y;
float var_Z = var_Y - b_s / 200.;
if ( pow(var_Y,3) > 0.008856 ) var_Y = pow(var_Y,3);
else var_Y = ( var_Y - 16. / 116. ) / 7.787;
if ( pow(var_X,3) > 0.008856 ) var_X = pow(var_X,3);
else var_X = ( var_X - 16. / 116. ) / 7.787;
if ( pow(var_Z,3) > 0.008856 ) var_Z = pow(var_Z,3);
else var_Z = ( var_Z - 16. / 116. ) / 7.787;
float X = 95.047 * var_X ; //ref_X = 95.047 Observer= 2°, Illuminant= D65
float Y = 100.000 * var_Y ; //ref_Y = 100.000
float Z = 108.883 * var_Z ; //ref_Z = 108.883
var_X = X / 100. ; //X from 0 to 95.047 (Observer = 2°, Illuminant = D65)
var_Y = Y / 100. ; //Y from 0 to 100.000
var_Z = Z / 100. ; //Z from 0 to 108.883
float var_R = var_X * 3.2406 + var_Y * -1.5372 + var_Z * -0.4986;
float var_G = var_X * -0.9689 + var_Y * 1.8758 + var_Z * 0.0415;
float var_B = var_X * 0.0557 + var_Y * -0.2040 + var_Z * 1.0570;
if ( var_R > 0.0031308 ) var_R = 1.055 * pow(var_R , ( 1 / 2.4 )) - 0.055;
else var_R = 12.92 * var_R;
if ( var_G > 0.0031308 ) var_G = 1.055 * pow(var_G , ( 1 / 2.4 ) ) - 0.055;
else var_G = 12.92 * var_G;
if ( var_B > 0.0031308 ) var_B = 1.055 * pow( var_B , ( 1 / 2.4 ) ) - 0.055;
else var_B = 12.92 * var_B;
R = var_R * 255.;
G = var_G * 255.;
B = var_B * 255.;
