Hey
I am trying to put a negative charge on points, but I cannot let it work.
Do you might know what I am doing wrong?
Thank you for your response
Checkout Dendro plugin. Chromodoris is good but Dendro is comparatively faster. Also has well documented examples.
It does not work for me, dendro. I only get invalid meshes with my larger geometries.
Do you know how get a negative charge in Chromodoris?
Chromodoris is fast and smooth.
But maybe I should just use Cocoon; or maybe Dendro; but Chromodoris is faster
Dendro is fastest of all. I have tried all three plugins. Give a try
I also have often invalid mesh with Dendro, there are no miracle but settings can cure (size, iso value and adativity to 0).
Hey @ForestOwl, it looks like you need to turn on Density sampling to get the total sum of values (positive and negative) - by default only the closest value is being sampled.
Cheers
