Rhino.Inside.Revit is used in many different situations. We supply 3 different build types to fit the best build type with your situation.
The build type can be set in Revit by going to the Rhino.Inside.Revit toolbar and selecting the More menu at the far left, then click on Options. In Options, select the Updates tab.
Build types include:
- Public Release - This is the default build that has had the most amount of testing. This stream will update less often.
- Release Candidates - Here are the pre-released versions of the public release. This is a good place to test any upcoming builds that may get deployed across a larger team.
- Daily Builds - Here are the latest updates to what we are working on. This is a good place to be if you want the very latest features we are currently working on. Be warned, it will update the most, but also the least tested.
