@software_comas, i’ve been using this way to do it:
Set go.AcceptNumber(True, False) to allow entering a number and put the code to setup command options in a seperate function eg. in below example this function is named SetCommandOptions(). Then you can clear the command options after a number has been entered and run that function again eg:
while True:
SetCommandOptions()
get_rc = go.Get()
if go.CommandResult() == Rhino.Commands.Result.Cancel:
return
if get_rc == Rhino.Input.GetResult.Option:
option_name = go.Option().EnglishName
# do something here if required
elif get_rc == Rhino.Input.GetResult.Number:
# set the entered number as current value for an option
optSize.CurrentValue = go.Number()
go.ClearCommandOptions()
SetCommandOptions()
else:
break
_
c.
