The choose object popup appears then quickly disappears
What version and build of Mac Rhino are you running?
Rhinoceros version: 5.5.2 (5F85)
Should i only post bugs that i know how to reproduce?
if this happens to anybody, the way to fix it is to press the down arrow before it disappears.
No, but if I can’t reproduce it, I can’t send it to the developer to be fixed.
That would not be a “fix” but a way to work-around the problem.
I’m still trying to reproduce it.
I am still unable to repeat the problem.
Are you using the trackpad or an external mouse?
Do you have a Spacemouse plugged in?
Please run Rhinoceros > About Rhinoceros > More info
Paste the contents into a plain text file and please send it in a reply.
I suspect there is something special or different about your setup.
This is not a commonly reported issue.
no spacemouse but i am using an external mouse.
Software information
Software versions
Rhinoceros path: /Applications/Rhinoceros.app
IronPython version: not installed
Evaluation expiration: 2 February 2019
Language: en-SA (MacOS default)
macOS version: Version 10.14.2 (Build 18C54)
Plug-ins
Third party kernel extensions
None
Hardware information
Computer hardware
Hardware model: MacBookPro13,3
Processor: Intel Core i7-6920HQ CPU @ 2.90GHz
Memory: 16 GB
Architecture: Intel 64 bit
Video hardware
Graphics: AMD Radeon Pro 460 4096 MB
Memory: 4096 MB
Screen size: 1680 x 1050
Displays: Color LCD (258dpi 2x)
USB devices
Razer: Razer DeathAdder Elite
Apple Inc.: iBridge
Bluetooth devices
None
OpenGL information
OpenGL software
OpenGL version: 2.1 ATI-2.4.9
Render version: 2.1
Shading language: 1.20
Maximum texture size: 16384 x 16384
Z-buffer depth: 24 bits
Maximum viewport size: 16384 x 16384
Implementation settings
Use texture compression: No
Appearance settings
Antialiasing: 4x
Mip map filtering: None
Anisotropic filtering: None
If you temporarily disconnect the external mouse does the problem remain?
I tested with and without a USB mouse (just a plain 3-button Logitech), and mine worked fine.
